How loud is the cooling fan on a Retail "Built by ATI" Radeon 9800NP/9800 Pro??
Yes, loud enough to be annoying. I have a Zalman + panaflo system. There's not a cooling device in my system that isn't one of those (power supply included) and even my panaflo L1As are kept on the bottom speed of a Vantec Rheobus.
Replace it w/ a Zalman ZM80C-HP.
I don't think they are that loud. The only fan that sounds like jet taxiing out is my Vantec Aeroflow for my proc.
Compared to a 5900NU/U, they're quiet. 5950U fans are even quieter in comparison to the previous cards (larger fan, slower fan rev).
It's not extremely loud, but it lets out this kinda high-pitched "WHHOOOOOOOOO" that is pretty annoying. Most small, high output fans do this. I'm going with a Zalman on mine.
Agreed. It's not that loud, but was the loudest whine in my case.
I replaced it with the Acrtic Cooling VGA Cooler as I was lucky enough to order one at SVC.com before they went out of stock. (They are the only US distributor and have been out of stock since 11/4.)
"Compared to a 5900NU/U, they're quiet."
agreed I owned both and my ati 9800 pro was very quiet , the loudest thing in my pc was my stock p4 cooler and psu!
"So loud I get flashbacks from ?nam, and think a Chinook helicopter is landing in my living room. "
your kidding right?
Originally posted by: NFS4
Would it be annoying in a nearly silent PC?
Yup B, I just R&R'd a 9800pro faned for a Sapphire 9800pro non-faned from newegg ($333) because of the noise. I hate noise when I'm trying to write papers and such so I have a near silent PC AND I have a desktop machine!
Sapphire 9800 pro
Burner- Samsung SW-252FENB Silent mode is very nice no aircraft whirly sounds
Zalman CNPS7000A-Cu- For CPU Mild OC of barton 2500+ to 2100mhz use is low rpm mode
1 case fan- Zalman 80mm Ca ZM-F1- Can't hear it
2-Seagate baras silent.
PS- Fortron FSP350-60PN with silent, very low varible, 120mm inside fan.
