The noise level depends a lot on what you are cutting and the surface. For example, if you stand a case panel up, you will hear a ton of reverberation.
The noise is annoying at the very least, but bearable without earplugs. But there's no reason not to pick up some ear plugs with your goggles and mask (you DO NOT want that red dust in your sinuses or lungs, trust me!).
