amd6502
I'm thinking of using a smaller SSD (~120GB) and using a partition slightly smaller than 110GB to install Win10 on (as C: drive). I'm wondering how long it will take for windose to degrade the SSD if:
a.) I do a straight install.
b.) I take minor precaution and disable the swap file on C: (and say move/enable swap file to a ferromagnetic drive D: )
Second question is, once windose is finished thrashing this partition, will this destruction affect the reliability and performance of the remaining ~10GB partition (which will be used for linux /usr/ ) on the SSD?
Also somewhat curious about the same question, but with an even smaller SSD, 60GB (so with a 50GB for windose C: drive). Will it simply degrade at roughly twice the pace (110/50=2.2)?
Does either of these have a clear durability advantage: SP120GBSS3S55S25AE or SU128GBSS3A55S25AC ?
