How long to zero a 2TB drive w/ dd over USB?
I'm RMA'ing a WD20EARS drive that failed WD's drive diagnostic tool due to too many bad sectors. I decided to zero out the drive with dd before sending it in. It's been running for almost 34 hours now.
I used the command: dd if=/dev/zero of=/dev/sdb bs=1M
I figured it would take about a day, but apparently it's a lot longer than that.
Is there any way to poll the program to see it's progress? Or do I just gotta wait it out?
did you ever answer this ?
Newer versions of dd (Ubuntu 16 and later, among others) have a show-progress feature built in.
If you want to do it the old fashioned way, use either pv or the kill -USR1 command, as outlined here:
