How long should CAT5 cable be at the max?
Muerto
1,937
The longest cables we have in our house right now are about 70 ft. They join three rooms. Is that too long? I've actually got a pretty sloppy network right now and I'm thinking of making some significant upgrades. How long should the be at the max? Thanks. :)
Mark R
16
The maximum length of cabling between 2 devices is 100 m for standard copper wiring (e.g. Cat5).
loner
380
Yep. You are fine as far as cable length goes. If you are cleaning your wiring up (and you are going to run it through walls/ceilings/attics/etc, spend some time in routing the cable. Especially focus on keeping the cable from running along electrical wiring (parallel with it) in order to reduce electrical interference.
BuckMaster
The total length of wire segments between a PC and a hub or between two PC's cannot exceed 100 Meters (328 feet or about the length of a football field) for 100BASE-TX and 300 Meters for 10BASE-T.
Supergax
639
If you plan on running through walls and around electrical lines or such I suggest STP (shielded twisted pair) to prevent interference. It really isn't that expensive compared to unshielded twisted pair, I got 80ft of stp for $23 bucks @ www.cableexpress.com
Dark
639
Buckmaster: It's 100m between 2 devices wheter for 10BaseT or 100BaseT. The total diameter is 205 for 100baseT and 2500 for 10baseT
Cnuke
186
Doesnt matter. 328.5 feet between devices for cat 5 data cabling it standard for 10 or 100. Will not pass Cat 5 testing if it is 1 inch over 328.5 feet. Will it work, I have seen it, but will not pass testing standards. Your answer is 328.5 between devices.
Gizmology
Banned
Jul 31, 2000
618
Uhmm when it comes to passing tests, it depends on what "equipment" you are using to test with. I doubt he has a WaveTek (so)....
-Giz
Mark R
16
Maximum length for RG58 coax (thin ethernet) is 185 m if I remember correctly.
Never had the opportunity to use 'thick' coax, so don't know anything about it.
BreakApart
1,313
Yes Buck that information is Wrong...
Here is cable length information on the CISCO site. They are the leaders in the networking industry. See Table 2-1
Find the section:
Cabling Considerations for Ethernet and Fast Ethernet Modules
Scroll down and find:
Table 2-1: Ethernet and Fast Ethernet Maximum Transmission Distances
Hope this helps...
