Originally posted by: Cyberian
I guess that measuring from the head unit to the speakers is out of the question.
Originally posted by: yamahaXS
why are you paying that much?
wire is wire, assuming its a big enough gauge to carry the amperage.
Actually, it is pretty common to pick up interference through speaker wire. My roomate put new speakers in the rear of his car and used cheapo wire. When he revved the engine, you could hear a whine only in the rear speakers (front were stock). The car had an aftermarket tach installed (previous owner), so he might have run his speaker wire too close to the wiring for that, but my point is that it's not entirely uncommon.Originally posted by: MichaelD
The odds of picking up noise thru wires carry SPEAKER LEVEL current is slim to none.
Now, if you were running a HU/amps system and had to route RCA cables carry PREAMP level current thru the vehilce, that's another ball of wax completely.
Buy regular 16-ga speaker wire and be done with it. I know a little bit about this stuff. See?
That being said, $1.50/ft is still too expensive, even for good wire.
Originally posted by: GroundZero
o.k. here is what you do. measure the distance that the wire will have to be routed, from the head unit to the speakers.
now subtract 3 feet from this total for being a dumb@ss.
i figure if you are so damn lazy as to not be able to run a tape measure that you will never install the wires to begin with.
so save your money and don't buy any wire...
Originally posted by: Ornery
Rockford Fosgate Riot Gamma Geometry Speaker Wire
Man, I GOTTA buy stock in these wire/cable companys!![]()
