- Jun 4, 2005
- 19,723
- 1
- 0
Originally posted by: Goosemaster
I jsut installed the modified hosts file....very nice![]()
Here. Put that after whatever is in your hosts file already. =]
Originally posted by: LoKe
But seriously, if you wanted to use it properly, you could do something like...
64.233.187.99 www.google.com
So that you try to connect to the IP, rather than resolve the address. ~_~
There is a slight problem with that though. Google rotates through at least 4 different server banks so that you get fresher results. About once a week or so they change IP's, or so I've seen.
That may be true. But I was just using it as an example. =]
Originally posted by: MS Dawn
If you really want to mess with them set their TTL to 3. :evil:
Originally posted by: RichUK
how do you do that, the default is 128 right?
Default on MS machines should be 128. Use the TCP Optimizer from speedguide.net here to change this value easily. It can also tweak (or mess up!) other settings with your stack.
