How long is PC3200 RAM going to be a "standard"
voodoo1694
496
I was curious if anyone knew some roadmaps of how long PC3200 DDR RAM is going to stay the standard (ie for non-overclockers) for RAM.
Mik3y
Banned
Mar 2, 2004
7,089
probably for another half yr or maybe longer. it really depends on if ddr2 turns out to be good enough for mainstream, especially for amd.
Bateluer
27,730
8
DDR400 will be the standard for a while yet, methinks. DDR2 won't be mainstream until Intel releases the successor to the 915/925 chipsets and we see an actual performance improvement.
Cerb
17,484
33
86
When mainstream DDR2 reaches 800MHz, we'll start to see a shift. Right now, even some mobos w/ the Socket T have DDR slots.
DDR2 sacrifices latency for speed, which is why 533MHz DDR2 is JUST good enough to keep up with 400MHz DDR (+33% speed). One of two things will happen to get it into our PCs:
1. Manufacturers start saturating the market, selling for cost or less, like with SDR and DDR.
2. Some games start using more than the current 3.2GB/s bandwidth in actual use, necessitating a change for the typical enthusiast.
3. DDR3 (based on GDDR3, maybe) comes out while DDR2 is still expensive, and turns out to be cheaper as well.
