Well, If you're using the PVC as a spudgun, I'd recommend at least 12 hours, but if it's just a water line, 7 hours will probably be fine. If you have the sprinklers on so there isn't as much pressure, you can probably turn it on sooner.
When I build spudguns, I have to get the fittings together and and adjusted in about 30 seconds, because after that they're stuck permanently.
