Originally posted by: HappyPuppy
The problem is more likely rusted hot water pipes than rust from your hot water heater, unless your heater is very old.
Modern hot water heaters have a glass lining on the inside. If you are getting rust from the tank, then the glass lining is gone and your heater is getting ready to flood your house.
I have found that hot water heaters are good for 12-15 years, regardless of the warranty. If you begin having problems with it just rip it out and install a new one. They aren't that expensive. Takes about 2 hours to do.
Originally posted by: Maggotry
Hot water heater. I love hearing people say that.![]()
Originally posted by: sharkeeper
Your water heater anode rod (sacrificial electrode) has expired. This looks a bolt head at the top of the tank. The tank doesn't need to be completely drained to replace it, just a few gallons (and most importantly!) all the pressure relieved! Putting this mangesium rod back in the water will stop corrosion. Even glass lined tanks will corrode around the fittings and element flanges (electric) in the absence of the sacrificial element.
Cheers!
