How long can you reach with a usb cable?
JackMDS
29,556
431
15 Feet is the Standard Max.
Explain what you actually need?
eflat
2,109
I just need a cable to reach my printer which is about 25 feet away.
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
Use a wireless bridge & print server. Or just run CAT5 over to there, then use a print server to connect it. Far more useful for sharing too.
eflat
2,109
yeah dar more expensive that a usb cable.
usb cable: $5
you're solution: $100
if i did that i'd just get a network printer
0roo0roo
64,795
84
yup active repeater/cable is what is required
probably ok for printer
for a usb drive i would trust it less
Zepper
18,998
Yup, USB repeater, wired or wireless, is the cost-effective way to go...
.bh.
Bateluer
27,730
8
.bh.
Wouldn't moving the printer closer be the most cost effective solution? :p
Zepper
18,998
Well, if the OP wanted to have the printer closer, we wouldn't be having this thread...
.bh.
imported_Baloo
1,782
It would be much easier and more cost effective to MOVE THE PRINTER CLOSER TO YOUR PC!. A cable long enough is going to cost as much as a printer. Network the printer, like as has already been suggested, if you insist on keeping it two floors down on the other side of the house(kidding). It would still be cheaper to buy a new printer and park it closer to you PC, then you can have the printer you got just for show.
RebateMonger
11,586
As noted, the USB spec says 15 feet max unless you have a hub or repeater or active cable in between. I've seen an HP printer fail even with 20 ft. of USB cable.
