how late is too late for street basketball?
rh71
52,844
1,049
god I hate the sound of bouncing balls late at night or 9am on a weekend.
Safeway
12,075
11
When it is too dark to see the ball, you stop playing ... only long enough to get a glow in the dark basketball.
KLin
30,224
568
Time to move your cardboard box from next to the basketball court?
Crono
23,720
1,502
Sundown. After that, you better be a vampire or packing heat. OR a vampire packing heat.
mugs
48,920
46
If it's near a house, 10:00 p.m. sounds like a good time to stop. You could close your windows...
RESmonkey
4,818
[atot] You can put together some crazy contraption that emits some frequency sound that disrupts their game and .... [/atot]
Nik
16,101
Could Dirk Digler get away with being bitten by a vampire and walking around naked?
angminas
3,331
26
Actually, you should be able to set up an anti-bounce that would reduce the volume, like in noise-reducing...
Uh...
Ok, you got me.
Jul 3, 2009
You can check the city ordinance for noise if you want to see if you can get the police involved to make it stop. If it is a public court, you could simply take matters into your own hand and take down the nets. This alone will discourage many from playing. If it is some neighbors, you will be pretty much out of luck unless you belong to an HOA and then you may be able to do something about it.
txrandom
3,773
So you are telling him to vandalize the court?
SP33Demon
27,928
142
In a black or white area? In the inner city they play til they can't see the ball and even then they'll turn the porch lights on and play. In the burbs usually until dark.
Apr 17, 2005
13,465
are there lights at this court? cause if there are, its clearly meant for playing past sundown.
or you could go out there and school those noobs. loser has to leave the courts.
Apr 20, 2008
10,067
990
You are a complete asshole.
I hope someone slashes your tires as an easy fix because they are tired of seeing your car on the road.
nuMERICA
13
Well... When I used to play every day in my younger days we used to stay up until 1-2am playing because the courts were lit. So there is no bed-time for streetball. If the courts are in close proximity to your window and the noise of basketball goes on after 11pm you could go down there and ask them to stop. If somebody had the balls to come down and ask that when I was playing, I would probably stop without much resistance (although very grumpily).
Doing passive-aggressive things like calling the cops or taking down the hoops will get you stabbed.
