Theres a company around here called City Ice Compny.
The side of their trucks say "The Colder Ice"
The bagged ice they sell, Ice Rounds ,
claims to be 33% colder than regular bagged ice.
How is that possible ?
Originally posted by: notfred
Are you people in elemetanry scool or something??
water, hydrogen monoxide.
let's start with water in a gaseous state, at 500 degrees F. We call this gaseuos form of water "steam".
Now let's begin cooling our water. down to 400 degrees. Still steam. 300 degrees. Still steam.
212 Degrees. Our water condenses into liquid form. I hope you're familiar with this.
200 degrees. Still liquid. 100 degrees. Still liquid.
32 degrees F. Our water freezes solid. We call this "ice".
Continue cooling our water.
0 degrees. It's still ice. -100 degrees. Still ice. -200 degrees. Still ice.
NOTE: the -200 degree ice is colder than th 32 degree ice.
Why? Cause we cooled it off more.
Your question is liek asking "how come some air is hotter than other air?" It's because it was heated more.
Originally posted by: bob970
they pack it in even colder ice.. which cools it down![]()
Yes, but in order to keep it at that temp, you'd have to have a colder freezer to keep it in, and it will eventually warm to whatever it's environment is. So I still insist that it is not "colder", it just cools faster because of the shape/size of the ice chunks.
Originally posted by: FoBoT
in reference to notfred's comment ^
actually, if you heat steam above 212F it is referred to as superheating
steam is normally 212F, if you run steam through another process to add more heat, it is "superheating" the steam above 212F
Originally posted by: timmyG
<a class=ftalternatingbarlinklarge href="http://www.vitazing.com/sam/monkeyrobot.jpg" target=blank>riiight</A>
Sorry, the engineer in me just has to say something.... You forgot to specify the pressure.
Ryan
Ryan
one standard atmosphere.
Also: A sphere is the object with the LEAST surface area per volume. It would NOT provide more surface area for heat transfer than, say, a cube.
We found it does cool ice faster...
Cools 33% faster than traditional bagged ice (from the ice bag's logo)
i know nothing of this chemistry, but i do know how to spell ELEMENTARY.
