How is my SATA and IDE divided on A8N-SLI Premium?
yacoub
1,991
14
That might explain the slight instability I've noticed on my system since I set it up a couple months ago that doesn't seem to show itself in all circumstances.
I have my PCI locked at 33.3MHz but I don't see a separate control for SATA or IDE dividers/locks in the BIOS. Can someone point me to where it is for this motherboard?
In particular, I am running my 3200+ A64 at 2.4GHz (10x divider, 240MHz I believe) whic his 3800+ speed. The process has no problems at all at this speed and runs pretty cool even with the stock hsf, however I'm concerned something in the motherboard is being overdriven a bit out of spec or whatever. I think it might be the IDE and or SATA channels and I'm wondering where to find the divider/lock for them to get an idea what they're being driven at and if I can reduce it slightly.
Both harddrives I've run (both SATA) have exhibited some sketchy performance and my DVD drive also has as well. Symptoms for the drives are hesitation/refreshing of folders when I open them, Event Viewer shows errors sometimes in the logs as well. DVD drive sometimes stops responding (drive tray eject speed slows down over time and eventually stops opening at all until I fiddle with it a lot and unplug/replug it (while system is off) and then sometimes it starts working again and the drive tray shoots open and closed very quickly at first and then slows down over time. Also when the tray gets slow and/or stops working completely, the drive shows up as a CD-ROM drive and no longer a DVD-R/W drive and I can't use it as a burner. Yes, strange gremlins indeed.
Case: Antec P150 SuperQuiet Mini-Tower w/ Antec TruePowerII 480w PSU
Board: Asus A8N-SLI Premium
Processor: AMD Athlon64 3200+ Venice @ 2.4GHz
RAM: 1GB pc3200 ddr400 Corsair Value Select on dual-channel (at 1T, CL2.5-3-3-7)
Graphics: Sapphire ATI Radeon X800XL Ultimate 256MB
Audio: Auzentech HDA X-Plosion 7.1 DTS
Toslink output to Logitech Z-680s
Storage: 200GB Samsung SpinPoint SP2004C SATA 7200rpm 8MB cache
160GB Seagate 7200.9 SATA 7200rpm 8MB cache
Thanks for any help!
