How is as rock for motherboards.
alanwest09872
1,100
I have a 1366 motherboard the evga 760. I am looking to upgrade it. I have been looking and the best one I can find is http://www.newegg.com/Product/Produc...82E16813157213 but I dont know how good as rock is for motherboards. So what do you guys think. Is this an acceptable motherboard or should I stick away from as rock. Its t he best one I can find with multi sata 6gbs and multi usb 3.0
Crap Daddy
610
As rock is as a rock. Now seriously don't know about the x58 for ASRock but the P67 Z68 series is pretty good. I own a P67 extreme 4 and works like a charm from the first boot. I also have another P35 from ASRock working after more than 3 years without any problems. But why do you want to change the mobo? It's dead?
jhansman
2,768
29
My current Asrock board has performed excellently, and I have high hopes for the one I am about to upgrade to. Don't know about their Intel boards, but I suspect they are equally good. Product support is also quite good.
sandorski
70,784
6,343
Asrock is decent. Usually has Hybrid setups or unique features that are uncommon.
