How infrequently can a car be driven without problems?
Status
Not open for further replies.
Sukhoi
15,342
104
I have a 2009 RAV4 that right now I only use for road trip vacations and ski trips. That means in the fall and spring I have little need to drive it. How long can I let it sit at a time before getting into battery or other issues? I generally drive it to the gym once a week, but I'd rather do it ever 2-3 weeks and avoid the mileage.
SSSnail
17,458
83
86
Why did you buy the vehicle if you don't plan to use it? I think a rental plan would fit you nicely.
Sukhoi
15,342
104
Oh I drive it plenty. Only owned it for about 1 1/4 years now, and already have 22K miles. :) Also my '95 Corolla isn't exactly the most reliable car in the world, so I really do need something else around for getting to work and whatnot when the Corolla breaks.
SSSnail
17,458
83
86
I used to have to leave my car for months at a time (usually 6 months ;)) and the problems I had were deflated tires, dead batteries (just require a jump even though I disconnected it) and putting new gasoline in the car. Probably a good idea to change the oil too if you're gonna leave it for that long (6 months at a time).
For three months time, you shouldn't need to do much except check the tires. As for your car, I think the quick short trips are far more damaging than leaving it. The car hasn't get up to operating temperature yet and you shut it down already.
LTC8K6
28,520
1,575
Every 2-3 weeks will be fine as long as the trip you take is long enough to charge the battery and get all the fluids up to temp.
jlee
48,518
223
Spend the ~$15 on a battery tender (the inexpensive ones at WalMart work fine) and keep your battery healthy.
Sukhoi
15,342
104
It's parked in a carport at my apartment, so unfortunately a battery tender is not possible.
The gym is about a 15 min drive, of which 75% is freeway. Especially on the way home I should be getting the fluids up to operating temperature. Sounds like I should be fine going more like 1.5-2 weeks between drives.
LTC8K6
28,520
1,575
I think you'll be okay.
hanoverphist
9,867
23
my stepdad leaves an old 96 chevy pick up at the airport in michigan for when he goes back to his "summer house". he just disconnects the battery and everything has been OK so far. hes been doing this for 3 years so far, same battery. the truck has over 200k miles on iit as well, with some overhaulin at about 160.
CurseTheSky
5,401
Driving it once every couple of weeks shouldn't be a problem. Just remember to do oil changes and whatnot based on time and not mileage. Twice a year or so should do it.
Status
