maniac5999
The backstory: I just got a 940, and it's stable at 3.4ghz with 1.43v. The issue that I'm having is that when I'm stress testing it using OCCT it flirts with 60* even though the top of the heat sink (Sunbeam CCF) is barely warm to the touch. This is in a 68*F (20*C) room in the middle of winter, and I don't normally air condition the room in the summer, even though it can hit 95*F (35*C)
Because of this, I want to know just how bad it is to exceed 62*. if it hits 65* or 70* occasionally under load in the summer would that be horrible, or no big deal? I'm asking this because a 62* max temp seems to be VERY low. My old Kuma was listed as fine to 73*, the L335 in my netbook is listed as fine to 95* (they're both 65nm, but even 73* to 62* is a big drop).
Also, I'm wondering if my board is reporting the temperatures as being higher than they really are. I've re-mounted the heat sink a couple times, using varying amounts of thermal paste and it doesn't seem to make a difference, it idles around 40* case open or case closed in a 20* room, when according to Frostytech it should only have a 21* delta to ambient under 150w load. http://www.frostytech.com/articleview.cfm?articleid=2271&page=5 Interestingly with my old Kuma, the temperatures seemed to be reported high as well, but I ran into the voltage wall long before the heat wall, so I didn't really pay attention.
What do people think? should I act as if my temperatures are 10* lower than they are? should I just shrug it off? Should i reduce my OC to keep it cooler?
Edit: The plot gets even thicker. Even conservative old AMD says the X2s can go to 70*, and they're the same d#%$ silicon as the X4 http://products.amd.com/en-us/DesktopCPUSideBySide.aspx?id=621&id=560
