how HOT is your pc running?
SWScorch
9,520
Athlon 1.0 @ 1365
Asus A7V
Alpha PAL8045 w/ 50cfm Sunon
Case: 25 C
CPU: 44 C
My CPU rarely is above 42, but I just cranked the heat cause I left the door open and the house got cold :Q
eyecandy
411
Mine ran so hot the power supply cut out!
Course, that's cuz I didn't notice when the fan died and it sat running for a few days without the fan.
~Chels <--- wants her computer back
Squisher
21,204
66
38C idle 42C running prime95 Case temps are 24C
XP2000+ running the FSB @ 141MHz so it comes out to about a XP2150
Running an Alpha PAL8045 with a 92mm fan on a homemade adapter
AnthraX101
771
Athlon XP 1900+ OC'd to 1.7ghz (between 2000+ and 2100+)
54c full load
40c on the graphics heatsink
Armani
ThisIsMatt
Banned
Aug 4, 2000
11,820
48°C - hsf is a bit dirty :) I have a new hsf coming as well. I plan to make some duct work, etc, to draw cool air straight in and make my whole system quieter. I would love to do watercooling, but I don't have the cash. I have some ideas for custom water blocks that I'd love to try out sometime :)
udonoogen
3,243
running a volcano 7. heard there was some type of way to keep it running the same speed the entire time? im feeding it air from a case fan from the side ...
bandXtrb
Banned
May 27, 2001
2,169
51C ... tbird 1.3ghz, no OC, with case open (case closed causes to overheat). It's a little hot but don't care because it has a nice quiet 80mm fan on it.
