Just got a 566 cel for my old asus p3b-f board and I think its running too hot. Have a globalwin heatsink (huge bastard) w/ fan on a abit slotkit 3 running at default. I flashed the BIOS to v1006 which supports the new Cumine cores and set the freq and vol thru that (didnt use the jumpers on the slotkit). Right now running prime95 torture test I'm getting around 60 deg Cel on the CPU via MBM 4.18. This seems way too high??!! I applied heatsink grease so Im pretty sure Im making good contact w/ HS. I tried OCing the chip but it wont go anywhere over the default even if I raise the Voltage up to around 1.75 (havent tried anymore than that). I know I prob have to tackle this heat issue first but my old 300A ran fine at 450 for over 2 years with this same setup Im using now (had old abit slotkit though). Any suggestions???...BTW this temp is with the case open and I also have a 80MM chassis fan in the front of the case pulling air in with the PS fan pushing air out.
