how hot is too hot?
cretinbob
Ok, I have a venice 3200+ I'm running at 2.6 on an epox 9npa board. while it was cold and my ambient temp was about 15c cpu temp was 35c top with a heavy load. now the ambient temp is creeping up, but my auto cutoff is set to 40c. how how can I safely bump that up to?
60~65c is fine, but only for short periods ideally, anything above that is bad.
Set cut off at maybe 60 or so and you'll be fine, but ideally temps should stay below 50c.
CPU is going to be fine up to about 60C. That being said, anything about about 55C I would start to look into better cooling options. But if you are running at 35C under 100% load, then you are doing fine. But would jump up your cut off to about 60C or so.
