Putting an ATi Silencer on there isn't difficult at all (and will help with your heat issues).
Some people will say that 76C is fine, but I'm of the opinion that it's too hot. How to find out for sure? Try some active cooling on the case (a fan of some sort) to try and get the temps down, and see if you're still having the issue.
thanks Ronin. I have one inlet and one outlet fan, I will first try doubling that. which Silencer would I need? I see Silencer 5 is good for x800 (R430), would that include my x800 Pro?
