Those are the limits of what Intel has viewed as acceptable opreting temps...Meaning you can run outside of that range but it may effect the longevity of the cpu. Acanthus is right...After that point it should start to throttle....Now the real question is where is that temp taken from in the cpu and how far off are you with your temp readings....
When you run WMD go ahead and start throttlewatch and place it in the background it will record...Temps will lie but if the cpu throttles lower mhz speed to compensate high temps then there is a temp issue...The fact you can play and only rais etemp 2c makes me think something is BS here....With obviously sub par cooling now and the fact that NOOOOO current HSF even water block would only have a2c swing from idle to load we are basically looking at bogus numbers...
Just run the flippin throttlewatch and run you WMD, prime95 (same time).....If you are not running 2 cpu intensive apps you are kidding yourself again cause it wont fully load the cpu and give you the true hottest temp. You need HT or 2nd virtual cpu to be loaded fully as well....
