I'm running a 3960x on an Asus Rampage IV Extreme with the voltage set to 1.50. System seems stable at 5.05GHz.
Cooling is via a Corsair H100, but the idle temps are 45-55 across the six cores.
Running Prime95 or OCCT sends the temps soaring to 90+
These figures seem very high .. what temps should I expect with this setup?
I'm using the stock fans with the H100, plus the fans in the Obsidian 800D.
