How hot is too hot? I have an Asus A7V mobo and AMD 800MHz thunderbird. In the case (which is a little smaller than normal) is only one fan (excluding the one inside the power supply): the cpu fan. And after just using the computer for about 30minutes, it gets to around 60degrees celsius. Is this too hot? Also I want to add a chasis fan and want to know which one is better: panaflow or coolermaster? Thanks for any info.
PS-
My computer locks up solid (mouse won't move, ctrl-alt-del won't reboot...) sometimes, when it does and i manually reboot, i go into bios to get these temps. Is the temperature what is causing it to lock up?
PS-
