How hot does the trunk of a car get?
Status
Not open for further replies.
neutralizer
11,552
I'm moving and shipping my car (it's dark gray) across the US and I figured that the easiest way to move my desktop would be to stick it in the trunk. Anyone have any experience with this? Does the trunk ever get hot enough to damage a computer?
Wyndru
7,318
4
The components get hot as it is when the computer is running, so I'd figure it would be ok.
I'd be hesitant to put an LCD panel in there though. I think screens are sensitive to heat.
I've moved my desktop in my trunk for 3 hours on a 90 degree day, it was fine.
neutralizer
11,552
Not taking my LCD, just the desktop. Even removing my hard disks and video card as I don't trust the amount of jolting that those can take from the auto carrier. So it'd be just psu, mobo, cpu, and case.
While the cores get really hot while the computer is operational, I'm not sure if it can handle the entire thing being exposed to around 140 F or so I hear.
mmntech
17,501
12
The trunk doesn't get that hot since it's not exposed to direct sunlight.
BoomerD
66,500
14,892
Most auto shippers won't let you ship the car with anything in the car or trunk. They don't want to be liable for loss.
YOU probably don't want to ship your PC across country in the trunk of a shipped car...if you actually want it to arrive.
xSauronx
19,582
4
seriously. suck it up and haul it with you, OP, or pack it well and ship it insured, pack the HDs separately, maybe the video card too. all insured.
moving is a bitch as it is, dont take any shortcuts...its not worth it.
mizzou
9,734
54
my uncle tony says, when you ride in the backseat, you got more things to worry 'bout then the heat!
Status
