- Apr 7, 2003
- 2,021
- 0
- 0
Is there a formula to determine how hot a resistor of a given size will get? e.g., 1/4 watt resistor will raise the ambient temp by 2 degrees?
I'd help you but it is too early for me to get into Re and Nu numbers and such bullshit.
you can weld steel with a 4 ohm resister plugged into the wall.
Dunno from where teh 92 Amp figure came , but since a speaker is a complex system, it isn't exactly 4 ohms. It varies significantly based on a number of variables. I recall my brother did that back in the day to get a new 15" Kicker. It took about 10 seconds to blow the house fuse - 25A. So I would put the impedance of that particular speaker (my brothers) around 4.8 ohms at 60 hz with 25A running through it - while gyrating at 60hz in and out of the magnetic field.
