Putting together a new htpc, going with microatx and trying to keep it QUIET. I'm wanting to go with an AthlonXP with this heat sink and probably replace the fan with a vantec stealth(assuming it clears in the case). There will only be one side-facing 80mm vantec stealth fan so I want to make sure it won't be too hot.
Also, I'm wanting to go with this board since it has everything integrated.
Key to this is small, quiet and inexpensive.
What say you?
What say you?
