How high will a typical yard rabbit jump?
dullard
25,759
4,281
Suppose you were to make an elevated garden and you didn't want a rabbit fence. Yet your yard is covered by rabbits. How high would you put that garden? That is, how high will a typical yard rabbit jump for potential food?
FoBoT
63,084
14
fobot.com
will the slope be vertical? or less?
even a steep slope would be scaleable by a hungry rabbit, i think it would have to be high enough and vertical enough that it is not practicle
BigJ
21,330
I'd get several of the hare's oldest and most competent adversary: the tortoise.
dullard
25,759
4,281
Vertical sides.
And sadly, the turtle ate the python after it was done with these cats. Now, it is too full to help with the rabbits. Thus, I'm back to square one.
crt1530
3,194
Cottontails and brush rabbits will not jump a 2-foot fence. Jackrabbits ordinarily will also not jump a 2-foot fence unless chased by dogs or otherwise frightened. Discourage jumping by increasing the above ground height to 3 feet. In snow areas, a higher fence may be required. Remember, once a rabbit gets into the fenced area, it may not be able to get out.
Google IS your friend.
Third page result for: jump inches rabbit height
I find your lack of Googling skills disturbing.
GuitarDaddy
11,465
It says 1 meter Here
But I'm sure it differs with different types of rabbit. A Jack rabbit for instance can clear a 6 foot fence, but your average cotton tail or domestic bunny rabbit 3-4 feet should be safe.
