A user will NEVER reach the write limit on a modern SSD before the drive itself keels over.
Yes. Not sure where this paranoia about wearing out SSDs come from.
On GNU/Linux it's trivial to move the cache to ram. I do it for theoretical speed improvements, but I honestly can't tell the difference between that, and an old spinning platter. If one was really concerned, a ram drive might work on Windows.
Google is also master of the noob farm
IE sucked for a long time with no spell check. Firefox (or similar) was my choice for years, especially on dialup because adblock and flashblock would save a ton of precious bandwidth. Chrome won me over with speed, easy printing and tabbed browsing. For me it had nothing to do with marketing by Google.
I believe IE is finally a good browser but I avoid it on historical principle. Opera never seems to work properly for me.
I don't know, Chrome has always run like garbage on machines with 1GB RAM for me, or on old Atoms, but then again so does Firefox Australis.
these days 1GB RAM isn't really enough for any Internet-connected device.
but these days 1GB RAM isn't really enough for any Internet-connected device.
My Win8.1 7" tablets with 1GB RAM and 16GB eMMC still surf the internet just fine, with Firefox 32-bit. Sure, Newegg takes some time to load, and it might be paging out parts of the page, due to the OS itself taking up 500-600MB of that RAM, but it ... works?
Now that Vivaldi has left beta, I'd think it's worth taking a look at.
There are a few basic things missing, though. Easier access to the Chrome Web Store for extensions, and Alt+Enter being the biggest ones I can think of right now.
I prefer it FF, at least. I have to keep Chrome around for GPM downloads.
IE is pretty good, once we have extensions I will probably switch to it full-time as well.I may very well just switch to Edge. Once it has extensions, I may not need an alternative.
My internal testing keeps revealing that IE is quite efficient at using computer resources (i.e. longer battery life). Especially when it comes to GPU-assisted video playback. Edge has picked up where IE11 left it off :thumbsup:
Having said that, Chrome is still pretty good and is my main browser for the time being.
Yeah, extensions are essential. Can't browse without a set of script/ad/flash blocking layer, at all these days. The Edge interface doesn't also appeal to me much though, wish it had looked more like IE11 or Chrome.edge does give me the best results in terms of CPU usage for videos, but still doesn't feel quite as smooth as chrome for general browsing for me, and yes, the biggest problem is lack of extensions, I just can't use a web browser like that anymore, but I would surely give it a chance if it had extensions.
Exactly. Pretty much everything that I watch with Chrome, my CPU has to do all the hard work. A bit annoying, especially when chrome://gpu ticks all the right boxes.The problem with chrome video is that Google is pushing vp9, but there is almost no hardware decode for it. So the CPU needs to do all the work.
Graphics Feature Status
Canvas: Hardware accelerated
Flash: Hardware accelerated
Flash Stage3D: Hardware accelerated
Flash Stage3D Baseline profile: Hardware accelerated
Compositing: Hardware accelerated
Multiple Raster Threads: Enabled
Rasterization: Hardware accelerated
Video Decode: Hardware accelerated
Video Encode: Hardware accelerated
WebGL: Hardware accelerated
