How hard is it to fix a power switch on a laptop
filterxg
330
I'm considering buying an laptop Duron 700MHz 256MB RAM, $100. It works fine, except the power button requires an act of god to turn on. Intermittent short I figure. Anyway how hard is this to fix?
corkyg
Elite Member | Peripherals
27,370
240
Never heard of a Duron - your best bet is to go on EBay and try and find the Service Manual for your machine.
dahunan
18,191
time is all you need :) take the battery out and then figure out how to get to the hardware part of that switch.. might need to be cleaned or replaced.. or maybe you could improvise it in some way
corkyg
27,370
240
Originally posted by: Ethan2099
you should only really need to replace the bezel where the power switch is.
OK - here is a power switch - where is the bezel?
SW
dahunan
18,191
SW
I think he meant to say remove instead of replace
pop off the whole large plastic piece that covers the power switch
filterxg
330
Thanks, I think I'm going to buy it and see if I can fix it. Its a Sony Vaio so there should be parts available if I need something specific.
Ethan2099
64
sorry about that, with Dells the power switch is part of the keyboard bezel, so I usually send out a replacement for the bezel alone when there's a power switch issue.
