Originally posted by: Aharami
Originally posted by: Riprorin
I'll be doing my cardio at 7 am and my weight training at 12 pm. Is that too close together?
how would you manage that. dont u work? or do you work nights?
Before work and lunch hour.
I've always been chubby around the stomach, so that;s a lot of "brown fat". Fat tissue that is a lot harder to burn off, because its been there so long and there is not sufficient bloodflow to that area.
I'm 5'8", 150 lbs with about 11 - 12% BF. I have a fairly muscular build.
I haven't done much weight training since my college days 20 years ago, but I can knock off 100 push-ups with ease.
I gave up weights due to a neck injury but I'm going to give it a go again.
I only have time for 3 days/week, 1 hr a session.
How hard is it going to bulk up a bit?
quit posting & start lifting!!!
(j/k)
i'd get a physician's opinion first (maybe an orthopedic specialist
in sports) if you have any problems at all with your spine.
the formula is: LIFT, EAT, SLEEP, REPEAT
Originally posted by: TubStain
Well, I am still fat in the stomach area, and I want to get really lean, siz pack lean, then I'll slowly increase my food, lay off the cardio a bit and start lifting heavy. I'm at around 14% bodyfat. I've always been chubby around the stomach, so that;s a lot of "brown fat". Fat tissue that is a lot harder to burn off, because its been there so long and there is not sufficient bloodflow to that area. It takes a lor to get rid of those last fat cells, if you have never been lean in your life.
lean->fat->lean is easier than fat to six pack lean directly.
I have the same problem but I just don't care enough to do anything about it right now. I guess I am going to have to switch up to hard liqs instead of beer to get rid of it. And of course add more abbs to my workout.
(j/k)
I have arthritis in my neck. I'll give it a shot and see if I can go.
Brown fat is nonexistant, except for in animals, and newborn babies. Anything that says it 'stimulates utilization of brown fat cells' will work wonders for your dog or pet hamster, but won't do a damn thing for you, besides lighten your wallet.
'stubborn' fat is actually the same as the rest of your fat, but the surrouding nervous system/adrenoreceptors/whatnot has a higher resistance to the internal chemicals/symptoms your body creates to mobilize fat cells into energy. I suck at describing it, but it's described very well in Lyle McDonald's book - "The Ultimate Diet 2.0"
They say 45 minute is all you need but even when I work fast I can't get my workout over in under an hour . I'm usually there at least an hour and a halfOriginally posted by: cressida
(j/k)
Text
That is where I basically started out.
You don't need to workout everyday, you can work out 3 times a day for 45 minutes. Just break up your routines. If you want to gain muscle, eat high protein and carbos at the same time.
That's not true. I've gained at least 5 lbs of muscle over the last 2 months or so while getting leaner and I am 49. I lift 4 to 5 days a week hard and do Cardio at least 3 days a week. I eat lots of lean Protien with Complex Carbs and drink Whey Protien Powder with Glutamine in the morning and a half hour after working out. In addition, muscle takes more calories to sustain so you can eat more calories and not gain any fat.Keep in mind that you can't gain all muscle without gaining some fat (unless you are taking steriods), so just bulk up then cut yourself down (cardio stage).
I do 10 minutes warmup on the Elliptical prior to lifting. I don't include that as my cardio. Then it depends on which muscle group I work on regarding the number of sets. I usually do three different exercise for my chest then I do two exercises for my shoulders and 3 for my tri's. The next day I do 3 exercises for my back and two for my biceps. On my third day I do two exercises on my legs and then three for abs. For the upper body exercises I do 3 sets of 10 to 12 and then go up weight enough were the most I can do is 4 or 5.I don't do this is my legs and ab due to a trick back. For Cardio I alternate beytween 5 miles on level 11 on the eliptical or and hour of power walking with 6 lbs hand weights on a hilly course in the nieghborhood. I give each muscle group a 72 hour rest before I hit it again and after two months I usually take a week off from lifting and do 5 or 6 days straight of cardio.Originally posted by: blackdogdeek
are you doing both cardio and weights on the same day?
i split my workouts so that i alternate weights one day and cardio the next.
cardio is at most 30 mins and weights are at most 45 mins(at most 3 body parts, 6 sets each, 10-12 reps, 1 min rest)
