How good is the stock fan/cooling in AMD tbirds? If i'm not overclocking, do i need a better hsf?
kgraeme
3,536
Give it a try. It should work fine. The retail CPU with their fan is covered under warranty. And it will probably be quieter than most other HSFs.
shadowscavenger
253
I'm running the retail hsf on my 1100, if the heat sink fails this summer in warmer temps theres the amd warrenty so you dont have to worry as much. since im not overclocking im just gona use the retail so i say it'll be good enuf thou i am tempted to fire up a beter fan like a ys on it thou. cause it's got a 15mm fan and would prefer a 25mm fan more efficient and quiter.
