How good are 120-Volt 'Inflators' for car tires?
preslove
16,754
64
Like this
http://www.homedepot.com/p/t/202871...252_desktop&AID=10368321&cj=true#BVRRWidgetID
I hate taking my car to the gas station for an air pump. $20 to be able to fill up at home seems like a good deal. Most of the reviews say that they use it for things other than car tires... Would this thing be a pain in the ass to use on my car?
I'm going to be close to a home depot with a couple in stock tonight, so getting this thing wouldn't even require an extra car trip, lol. Should I buy it?
Jimzz
4,399
190
Those work ok but they wear out fast and take time to fill a car tire up. Couple PSI not to bad but if flat I would use something else.
If you do get one don't run it to long. If it starts to get hot stop and let it cool down. They will burn out real easy if you work it to hard.
highland145
43,973
6,338
for $20, I don't see where you can go wrong.
I have a battery powered battery jumper/compressor/etc one. Great for bike tires....real slow for car tires but it works.
Capt Caveman
34,543
651
Like this
I have one that you can plug into a car lighter that I can in my trunk. It's a little slow but still works fine after ten years or so. The gauge on mine is inaccurate so I have a separate tire pressure gauge to check pressure.
preslove
16,754
64
How long is long? My car's tires are 32 psi. Let's say they go down to 29. How long would it take to get them back to 32?
preslove
16,754
64
I have a 120 volt plug in my car, so I guess I could run this from that in an emergency :).
PottedMeat
12,363
475
i hook up my 12v inflator to my car, turn on the car and it takes ~2 minutes i think for that little
WilliamM2
2,985
876
I got a 4 gallon air compressor for $50 10 years ago at Advance Auto, it has held up very well, even did a couple of roofs with it. Still looks and works like new.
But if a tire only needs 3-5 pounds, I can fill it with a $5 bicycle pump faster than I can uncoil the hose, and coil it back up on the compressor.
Sep 7, 2009
12,960
I like the 'jump boxes'. They're self contained 12v batteries you can take on vacation, camping, wherever just in case you need a jump.
They usually have built in air pumps. $60 or so at costco.
NutBucket
27,154
635
This. I use a bike pump all the time. Works great and burns a few extra calories.
Spicedaddy
2,305
77
Same here, useful for slow leaks...
If I was getting something to keep at home, I'd get a cheap compressor instead of the 120V inflator.
JCH13
4,981
66
If it's something you're going to take on the road, one of the battery powered jobbers is a good call. If it's going to be AC powered get a small compressor for $50-60. It will be useful for many other things in addition to making car tire inflation go much more quickly.
I've got a 12v guy to do tire pressure adjustments at the track... can take several minutes to raise pressure 4-6 psi on a 15in wheel/tire combo. Very annoying.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
For emergency use, they're fine. To inflate a tire fully may take 15-20 minutes, but if you're only down a few PSI and need to "top off" the tire to let you limp to a repair shop having a little pump like this is helpful.
Still, I think these are better if they're 12-volt units designed to plug into your car's lighter. If you're going to have something at home, I tend to think that it's generally more efficient to just have a small compressor with a "pancake" tank.
ZV
Kelvrick
18,422
I have this one: http://www.amazon.com/VIAIR-85P-Port...=tire+inflator
Works great.. Probably takes a couple minutes per tire and I release down to the appropriate pressure with my gauge. Use it quite frequently for autox/track days and maintaining the daily driver.
I have that one too. I don't know what you guys are talking about, but inflating my tires from say 30psi to 34psi only takes like 15-20 seconds per tire? I run it directly off the car battery with one of these though.
http://www.amazon.com/Roadpro-Batter...gy_auto_text_y
mmntech
17,501
12
They work okay but they're not great. I highly recommend investing in a good quality air compressor. You can get a decent small unit for not too much money. Fills up tires quick plus they have a huge number of uses around the house if you're in to any sort of DIY.
JCH13
4,981
66
