How geometry geeks get free drinks
Kelvrick
18,422
Originally posted by: tfinch2
Originally posted by: jjsole
Originally posted by: MichaelD
He cheated. He had the napkin folded over in his LEFT hand. I watched it over and over. His fat hands hide the bulk of the napkin.
The camera angle changes quickly, so it's hard to spot. But you can see as he's preparing to wrap the napkin around the glass, the napkin is really long. As he UNwraps it, it looks really short, then suddenly when the camera changes angle, it's really long again.
Slight of hand and bullshiit. He cheated.
Absolutely correct imo. The napkin was folded for measuring, and then unfolded for comparison.
http://pics.bbzzdd.com/users/tfinch2/glass1.jpg
http://pics.bbzzdd.com/users/tfinch2/glass2.jpg
Height of glass is 7 inches, circumference is about 9.42 inches, and this glass has about an extra 3/4" of glass on the bottom.
That glass curves in at the top too, so you're at a disadvantage. I won a pepsi at work using my empty pepsi can and a box of paperclips.
TuxDave
10,571
I tried it and it really looks like it shouldn't work but it does if you remember pi*d.
XZeroII
12,572
He is correct, but I think that they are using a special lense to make the glass look narrower than it really is. When they do a close up near the end, you can see that it is a much wider glass than you initially think.
Snapster
3,916
Not really geometry geeks, but the bbc show (the real hustle) is about con artistry and scams that goes on in the world.
DrPizza
Mar 5, 2001
49,601
166
111
www.slatebrookfarm.com
Didn't look right to me... Someone can probably do a screen cap to verify. The length around the circumference is only slightly more than 3 times the diameter. (3.1415... times the diameter, actually.) That height looked closer to 4 times the diameter.
tfinch2
22,114
Looks like the aspect ratio of the video is more narrow than it should be. Look at their faces. They are all vertically squished.
Kyteland
5,747
I saw this on Fark. I liked the one they did with the whiskey and water better.
