how fast does electricity travel?
gregulator
631
4
well i have yet to find a good answer to this question and was wondering if anyone knew or had a proof, lab report, or link.
DRGrim
459
At the speed of light. It's something like 186,000 miles per second, right?
Russ
I think it would travel at the speed of light if it were not for the latency caused by the transmission medium.
Russ, NCNE
N8Magic
11,624
Doesn't the resistance of the transport medium slow down the flow of electricity?
ie. gold vs. copper?
brxndxn
8,475
It depends on the resistence... No resistence, then speed of light. Electricity traveling through gold is much faster than electricity traveling through salt water. (I think)
BigToque
11,700
It goes the speed of light, minus whatever the resistance of the wire its going through.
gregulator
631
4
well thats what i thought, but i couldn't find any lab reports on the actual speed vs. theoretical. thanks
Sohcan
2,127
The actual velocity of the individual electrons as they travel down a wire is on the order of 1 millimeter/sec...this slow drift velocity is the result of the numerous collisions that occur between the electrons and the atoms of the metal. Because of these collisions, an electron will travel in a "zigzag" path in the wire, changing direction each time it encounters an atom. But because of the voltage present, the "average" speed will be in the direction of the voltage, albeit very slowly.
The speed of an electric pulse is obviously much faster, and is the result of the voltage being applied down the wire. Thus, when you flip a switch on a light, the electric pulse travels on the order of 1/3 the speed of light, depending on the wire's resistance.
N8Magic
11,624
<< If a bolt of lightning hits water, does the water splash? >>
Yes.
When the bolt of lightning hits the water, it will superheat the water, causing it to vaporize. As this vaporized water moves away from the impact zone, the other water will be pushed out of the way, creating the effect of a splash.
