How fast does 350Mhz Cat5 Cable transfer at?
John
Moderator Emeritus<br>Elite Member
It's got a P2 350 inside..... ;)
Your dorm is probably going to have a 100Mbps connection, so this cable will be fine.
BurnItDwn
26,263
1,764
350mhz cat 5 is entanced cat 5, the cable should be capable of gigabit speeds, however, unless you have a gigabit network card, and the network equipment (switches, routers, hubs, whatever) is all gigabit (i doubt it is) you will get much less. Probably 10mbit in the dorms, or maybe 100mbit
