How far will a Barton-M XP2600 do at stock voltage w/TT SilentBoost?
Lyfer
5,842
Will it be able to do 11x200 atleast at stock?
Rig planned:
Abit NF7-S
Barton-M 2600
TT SilentBoost
1GB PC3200 (corsair or kingston valueram)
Apr 17, 2003
37,622
nothing is guaranteed, its all about the stepping you get
i would assume 200*11 will be more than doable on stock though
myocardia
9,291
30
Yeah, you've got the best performing mobile chip there is (at the moment, anyway). And if you've got the best stepping, it will more than likely do over 11x200 on stock voltage, assuming you mean 1.65v. If you mean 1.45v, who knows. Nobody buying these chips is trying to run them at 1.45v, unless they're using them in an HTPC.
drewdogg808
1,513
mine did 11x200 at stock (1.42actual), so did insane's i believe.
hopefully you'll get a good stepping w/some luck. :)
BlueWeasel
15,944
475
I'll let you know on Wednesday, as thats when my 2600M arrives (using a TT Silentboost on my currrent chip now).
myocardia
9,291
30
Hey, I'll let you know in a few hours (hopefully less!), because my XP-M 2600 arrived this afternoon, though I will be using a Thermalright SLK-900a and a 92mm Vantec Tornado.:D I don't mind hearing my computer running, obviously! BTW, why do you care what it will run at 1.45v? They are desktop chips, hence running them at 1.65v is running them "non-overvolted". They're just the best of the best desktop chips, so they pull them, so they can be used in a laptop.
