Originally posted by: Paladin
I have sent 10baseT over 350 feet on no-cat underground telephone cable. There is *signal loss* no matter how long or how short the cable is. But this is a digital signal, not analog. Signal strength and signal to noise ratios do not matter as long as the receiving end can still determine if it is looking at a one or a zero. Until the signal drops below this threshhold there is *NO* loss of effectiveness. The cable will either work, or not work. (there are, of course, rare exceptions.)
The shorter the cable the more you can abuse it before it will not pass data. The specifications tell you how you *should* run it (1" minumum bend radius, no tight wrap-ties/staples, etc.) and how far it *should* go (above mentioned 100 meters including patch cables if any.) What it *will* do can only be determined by actual on-site testing with a working signal.
That said, you want to stay well within specs.
