a router is a go-between between the internet and your local area network, it protects your computer by utilizing a technology called network address translation, which translates the internal lan ips to the internet ip which allows you to surf the internet safely. go to www.practicallynetworked.com very good site on this subject and has lots of router reviews, etc.
