How easy is it to change out a CMOS battery?
CheesePoofs
3,163
You just remove the old one and put in a new one. I'd think the hardest part would be making sure not to drop the battery into the case.
MuffD
6,027
Should it just pop right out? What would happen if I drop it in the case? Could it damage anything?
Edit: I just popped it out...Thanks for your help!
