I haven't built a computer for myself in a very long time. I'm still using an old XP1800+ machine with a 9800 pro. Looking to build a decent mid-range system for moderate gaming and all-around use. Not looking to overclock at this time.
How does this look for starters?
Western Digital Caviar SE16 WD2500KS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM - 77.99
http://www.newegg.com/Product/Product.asp?item=N82E16822144701
Crucial Technology 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 667 - 229.99
http://www.newegg.com/Product/Product.asp?item=N82E16820148017
GIGABYTE GA-965P-S3 Socket T (LGA 775) Intel P965 Express ATX Intel Motherboard - Retail - 115.99
http://www.newegg.com/Product/Product.asp?item=N82E16813128017
Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor Model BX80557E6400 - Retail - 220
http://www.newegg.com/Product/Product.asp?item=N82E16819115004
SAPPHIRE 100176L Radeon X1950PRO 256MB GDDR3 PCI Express x16 CrossFire Video Card - Retail - 199
http://www.newegg.com/Product/Product.asp?item=N82E16814102061
LITE-ON Black 16X DVD+R 8X DVD+RW 8X DVD+R DL 16X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 24X CD-RW 48X CD-ROM 2M Cache ATAPI/E-IDE 16X DVD Burner - Retail - 30.99
http://www.newegg.com/Product/Product.asp?Item=N82E16827106013
Antec LifeStyle SONATA II Piano Black Steel ATX Mid Tower Computer Case 450Watt SmartPower 2.0 ATX 12V V2.0 for AMD & Intel systems Power Supply - Retail - 59.99 after MIR
http://www.newegg.com/Product/Product.asp?item=N82E16811129155
Dell 2007FPW - 339
Total ~ $1300
Still trying to decide on video card. I mostly just play WoW, but would like something decent enough to make modern games at least playable at the monitor's native resolution. I'm coming from a Samsung 955DF 19'', and the reason I haven't switched to LCD is because I don't want to sacrifice color reproduction/black level/contrast that I'm used to getting from a CRT. I want a monitor with good image quality that's still serviceable for gaming. (but nothing more expensive than the 2007FPW). The x1950pro looks to be a good card for my needs, think it will be sufficient? Benches seem to put it at the level of a x1900xt.
Open to suggestions on all components.
Thanks in advance for any advice.
Dell 2007FPW - 339
Total ~ $1300
