How Does This System Look? Help!
marcdisa
Banned
Nov 21, 2009
61
I have a limited budget and wanted to build the best bang for the buck system and would just like everyone's feedback. I use the computer for internet, managing music and picture collections, and some gaming. I am looking forward to playing Star Trek Online, SW Old Republic, and Diablo III. I currently play some WoW and Lord of The Rings Online. I'll be running Windows 7 x64 most likely as an OS.
Processor: Athlon II 240 2.8GHZ Dual-Core
Motherboard: BIOSTAR TA785GE 128M AM3/AM2+/AM2 AMD 785G Micro ATX
http://www.newegg.com/Product/Produc...-155-_-Product
RAM: 2GB Kingston DDR2-800
Hard Drive: 320GB Western Digital SATA-II
Video Card: Gigabyte Radeon HD 4670 1GB DDR3
http://www.newegg.com/Product/Produc...82E16814125277
PSU: BFG Tech BFGR550WGSPSU 550-Watt Power Supply
Case: COOLER MASTER Centurion 541
http://www.newegg.com/Product/Produc...-088-_-Product
Markfw
May 16, 2002
27,294
16,126
For win 7, you better get 4 gig memory (2x2gig)
Nvidiaguy07
2,846
4
i think your better off with an E5200 cpu and then get yourself a better Mobo, and like they said 4GB of DDR2 is super cheap, you might as well get it.
Intels overclock better
