Current setup can be seen in my sig. Antec 1080amg case. Stock cooling on the CPU and video. 5 case fans and one of these for my Raptor. Out of the 5 case fans the two rear and the side are whatever stock ones came with the case. The two I have up front are Antec Smartcool Plus's. So =
Currently
(2) Rear fans = stock Antec 80mm's
Side fan = stock Antec 80mm
HDD bay fan = 80mm Antec Smartcool Plus
Front intake fan = 80mm Antec Smartcool Plus
HDD cooler = Antec HD Cooling system
ATI 9800Pro AIW = stock cooling
P4 3.0c = stock cooling
My stuff runs plenty cool already and I do not OC so massive cooling isn't a huge concern. What I mainly want is less noise. Here is what I am thinking of switching to =
What I am thinking about
(2) Rear fans = 80mm Panaflow L1a's
Side fan = 80mm Panaflow L1a
HDD cooler = Get rid of it*
ATI 9800Pro AIW = Arctic Cooling VGA Silencer, Model "AVC-1000 REV.3"
P4 3.0c = Thermalright XP-90 and 92mm Panaflow L1BX
* = I got my Raptor when they first came out and had heard they run hot so I bought this cooler with it because...well I am a sucker for gadgets. I don't think I really need it though, expecially since I can put the drive in the bay that has a Smartcool blowing on it. So probably going to ditch the HD cooling system. Though I unplugged it last night and couldn't tell any real difference in overall noise level (of course once I quite the CPU down that could change, and the two temp reading diodes I can stick just about anywhere with a front LED display is kinda cool). So depending on how loud it is over the new stuff it may go or stay.
As you can see I plan to change out the cooling on my CPU (Currently probably the noisest thing in there) and video in addition to some case fans. While I know the XP-120 would be quieter, it appears I would have to bend some caps on my MB to get it to fit which I am not interested in, so XP-90 it is out of those two. And as far as the stock 80mm fans go, are the L1a's a good swap or should I go with a different Panaflow? Or something else entirely?
Those are my main questions/plans right now. Thoughts?
Currently
