how does the nforce's sound compare to audigy or tbsc
girlsfavtoy
15
I wanted to know because i might be purchasing either a kt266a with an audigy or tbsc, or nforce-c (without vga).
Thanks.
sandorski
70,806
6,362
I can't say from experience, but I've heard others say that they couldn't tell the difference.
tomrizzo
Banned
Mar 14, 2002
221
I would suggest going after the kt266a and a seperate soundcard, and the audigy has my favor. Plus you can upgrade or change the sound to your liking later down the road if you have to.
RanDum72
4,330
I can say that that the Nforce board is as good, if not better, than Audigy. It sounds good in music (like the Santa Cruz) but at the same time its offers very low CPU utilization in games. The best of both worlds and its one of the main reasons I got an Nforce board (actually, I have two:)).
same thing here. i'm getting rid of my sblive/p4 to get an nforce/xp. i already have one nforce that i just love, and the sound is superb. my firend has an audigy platinum ex, and for games and music they sound just the same. i hooked them both up to my stereo, spdif and 1/8 plug run on hifi cables to a yamaha rx795a reciever/amp and to definitive bp6b tower speakers, and listened to a rather lengthy q3 match demo, a long tribes 2 match demo, and some mp3s, and i would give a slight edge to the nforce's sound, but for the most part they sounded identical. given that the msi nforce is a lot cheaper than an audigy + via kt333 or even kt266a, i'd be hard pressed to reccommend anything else but the nforce.
tboo
7,626
I have an nforce board & an audigy & untill nvidia releases bass & treble controls in their drivers im not touching the onboard sound.
Exposed
<< I can say that that the Nforce board is as good, if not better, than audigy. It sounds good in music (like the Santa Cruz) but at the same time its offers very low CPU utilization in games. The best of both worlds and its one of the main reasons I got an Nforce board (actually, I have two). >>
Do you play games at all? I just went from a Live! to an Nforce motherboard and I'm seriously considering buying an Audigy. From a gaming standpoint I do not like the way how the Nforce audio handles EAX or legacy sound.
Unimpressed with Nforce audio
