how does the 4.0 GPA scale work
Kenazo
10,429
I took my BA in Manitoba where we have a 4.5 grade scale
A+ = 4.5
A = 4.0
B+ = 3.5
B = 3 etc...
Now, in the standard 4.0 scale that seemingly every US school uses, are an A+ and an A both 4.0?
Glitchny
5,679
there is no A+ just A so just move A-4.0 and everyhting else accordingly
EDIT: Actually its different still
4.0=A
3.66 = A-
3.33 = B+
3.0 = B
2.66=B-
2.33 = C+
2.00=C
etc
gopunk
29,239
i dunno.. but at my school it's basically
3.5+ = good
3.3-3.4 = okay
3.0-3.2 = mediocre
anything lower sucks
the official system is:
A 4.0-3.9
A- 3.8-3.5
B+ 3.4-3.2
B 3.1-2.9
B- 2.8-2.5
C+ 2.4-2.2
C 2.1-1.9
C- 1.8-1.5
D+ 1.4-1.2
D 1.1-0.9
D- 0.8-0.7 Lowest passing grade.
E 0.0 Failure or Unofficial Withdrawal.
No credit earned.
ViRGE
Elite Member, Moderator Emeritus
167
Most standard school systems use a 4,3,2,1,0 system; so no half-points or anything, so an A+, A, and A- are all the same thing, a 4.0. The other common system on a 4.0 scale is "third points" where A is 4, A- is 3.666, B+ 3.333, B 3, etc; I've never seen a system like yours.
Kenazo
10,429
so a B+ would still be a 3.5? Good. I had no A+'s anyway, so my GPA wouldn't be affected by the transition to a 4.0 scale.
Kenazo
10,429
uh oh.. it would actually drop considerably, b/c I had a few B+'s that counted as 3.5's at the University of Manitoba, thus keeping my average up. I think I had a 3.46 or so, but If all my B+'s just got counted as B's, then My Gpa would be a 3.2 or 3.1.. :(
Lonyo
21,938
Why not just give it a grade (like A/B/C etc) rather than a number?
We have grades for each subject in the UK, using the letter, and we use A and A*.
Do you give the GPA only, or do you ever have the subjects you took?
Kinda sucks if you just give a number, a bit meaningless without much else IMO.
wyvrn
10,074
I have gone to two major colleges. For one it was 1-D, 2-C, 3-B, 4-A. The other used the +/-, so A was 4, A- is 3.66, B+ is 3.33, B is 3.0, B- is 2.66, and so on.
As you can imagine, it is harder to get 4.0's on the +/- system because you have to do 4% better on everything, and 4% out of a remaining 10% of points can be difficult.
LS20
Banned
Jan 22, 2002
5,858
well the number corresponds to a letter grade..so i dont understand what the problem that you see?
CaseTragedy
2,690
also depends on the univ. your applying for. the admissions office generally converts it themselves. in the UC system, B+ != B. just ask the admissions office of the school you're planning on attending.
