how does TERMAL GREASE work? how to apply it? is it also work like glue?
Outlaw
284
Thermal paste is by no means a glue. Its an interface material.
There are a few choices for your needs though.
"Frag" tape aka Thermal adhesive tape or epoxy.
Frag tape is not a good performer for heat transfer compared to thermal pastes.
Epoxy works well but is permannent for the most part.
What we have found is that using "Arctic Silver " or "copper paste " does have enough strenght with surface tension to hold most smaller heat sinks on to a surface.
Such as vid card heat sinks and the like. Still you need a retension mechanism for larger heat sinks.
jonnyGURU
Moderator <BR> Power Supplies
Moderator
Oct 30, 1999
11,815
104
If you need a glue like compound, may I suggest &quot;Arctic Silver Epoxy&quot;.
From the folks that brought you Arctic Silver, only it's a two stage epoxy. ;)
DaddyG
Banned
Mar 24, 2000
2,335
Thermal Grease 'works' because it effectively displaces air. The grease conducts heat better than air. It should be applied fairly thin using the edge of a razor blade or credit card. The precise 'thickness really depends on how smooth and flat the bottom of the heatsink is. Real smooth gets a thinner layer.
glen
15,995
Poit has about the best guides on the net for these sort of questions. He even has some animated gifs showing you how to apply thermal past.
Poit's Place
jonnyGURU
Moderator
Oct 30, 1999
11,815
104
Fall off?
What are you putting it on? Video card, I guess.
Like I said Arctic Silver 2 part Epoxy.
