<< actually there's more to the ps1 copy protection than that. otherwise something like clonecd would prolly be able to copy them. their solution (which i consider to be almost as clever as the gamecube's protection of simply making cdrs not fit) is to write some number of sectors as all 0s. (it's been a while since i've read up on this, so some things may not be 100% but it will give you an idea). since data cds are written with parity checks to the sectors, a sector containing all 0s fails the check and burners will automatically "correct" the data. the only way around this is with a hacked up burner or using a mod chip. >>
No because there are copy programs that will do bit by bit copying ignoring parity and error checking.
<< Are there any CDRW's that can acually replicate this by "going the exra distance" Or what about duplicating machines? I know some of them have higher quality cd burners. >>
It's not an issue of quality.
Sony makes playstation CDRoms that can read closer to the center of the disc than standard CD roms.
For exmaple (made up numbers), a regular CDRom has a center area of 20mm diamater. That 20mm area is just nothing, it's the mounting area for the motor. No data can be written to or read from that area.
You could pay many thousands of dollars for a proffesional CD stamper like Microsoft uses to Cut Windows XP CDs, but it still won't write data to that 20mm circle that CD readers can't read from.
Now, on the playstation CDroms, Sony decided this 20mm circle would only be 18 or 19mm instead of 20. Then they have a slight area where no standard CD Recording or Reading equipment can Write or Read.
Then since your CDRW is not physically capable of writing to this area since on a normal CD it doesn't exist.
Sony uses this bit to encode boot data, if it's missing it goes to the CD play screen rather than playing the game. It's not so much how it tells a real game from a CDRW game.
It's how it tells a game from anything else, so it knows whether to run the game, or go to the Music Player program.
I'm not 100% sure if this is accurate, but that's the best description I've managed to gather.
