WinkOsmosis
Banned
How are those canisters of liquified oxygen flammable? How does oxygen burn?
Originally posted by: Synergy
what if you remove all the oxygen? 🙂
Originally posted by: JohnCU
So, if you opened up the canister of liquified oxygen and put a match to it, nothing would happen?
No. The match would explode violently, as it burns at an enormously increased rate in the presence of the oxygen.
I've seen this done with a cigarette which is normally a fairly slow burning item. It produced an extremely bright flare for about half a second. There was just a little bit of ash left - even the filter burned.
Assuming you mean put a tiny opening in a canister liquified oxygen, it would escape at such a velocity that it would blow the match out. 😉So, if you opened up the canister of liquified oxygen and put a match to it, nothing would happen?
Well, in effect, perhaps, but the term "accelerant" is already reserved for other types of fuel used to make something ignite or burn more intensely or faster.So oxygen is an accelerant. Gotcha.
It's not an accelerant as such - without it things wouldn't burn at all. The rate of reaction (burning) is simply dependant, in part, on the concentration of oxygen.Originally posted by: TheBoyBlunder
Oh, so oxygen just makes things easier to burn. Right? *crosses fingers*
