Originally posted by: alfa147x
Thanks for the tips chuck
Ill look into the SI-1 stuff, can i find it advance, autozone, napa? or is it an online order?
I did read about the Seafoam and might look deeper into it, lets first see how the next tank runs
Well, it used to be at Advanced up here in the Chicago area and then they cleared it out...nothing like getting a $10 product for $2 on Manager's special clearance...
I've seen it at Pep Boys up here, never at Autozone, and not sure about NAPA. If you have a Pep Boys by you, drop on in and look for it there...they probably have it. Just go with the whole thing in your tank as a shock dose.
I was reading this:
http://forums.nicoclub.com/zerothread?id=126583
what if i just use the two parts and not the 3rd ?
<<1) use 33% on gas tank with 9-10 gallons of fuel. Cleans fuel injectors, fuel lines, removes moisture from fuel lines. Put it in gas tank at the gas station, then fill it with 9 gallons of fuel, so it can mix well. Just read the bottle for the normal mix ratio.
2) another 33% goes to your crankcase. so open your oil cap and pour it in. *WARNING: It thins out your oil. DRIVE FOR ABOUT 10 MILES, THEN CHANGE YOUR OIL. KABISH??
3) Rest 33% goes to the intake manifold. It cleans intake valves, cylinder, top of the piston, exhaust valves, etc. To do this, you have to use any vacuum line that goes to the intake manifold. In s13, brake booster line is perfect.
Actually I would go with nothing in the tank except the Redline, and would forego the Seafoam in the crankcase (no reason to do a solvent based flush in place of a real cleaner like Auto-RX).
The only thing I'd use Seafoam for is the step 3, and I'd use the whole thing as described. Couple of common tips I've seen when using it are 1.) don't let the car suck it all up too fast to begin with, let it just use it so it's not sputtering and dying (might have to manually hold your throttle open
a small amount to accomplish this), and 2.) at the end of the Seafoam, let the engine suck it up enough to stall out. Then you let that soak in for 10 minutes or something like that and start it up and drive.
If you're going to do this, I'd do it like:
1.) Run your current tank down to E, fill it back up, and run that tank down to E.
2.) Put one bottle of Redline SI-1 in and fill the tank up with 89 octane fuel.
3.) Do the Seafoam thing.
4.) Run the tank w/ Redline down to E, fill it back up, and run that tank down to E.
5.) Fill tank back up and change your oil (so if you're able, do all this about 4 tankfuls of gas before your next oil change...that, or just extend your oil change if you run short OCI's or short change the OCI).
Personally since I go overkill, on the oil change I'd go with an Auto-RX run, but then I tend to take things to the nth when I do sh1t like that...
Chuck
