Comdrpopnfresh
If one were to add an older, yet still capable, graphics card to a single-gpu system (all ati/amd gfx cards for simplification), how would that work? I have no interest in CF/SLI/HYDRA'ing cross-generational cards, but will any functionality be limited in either card for independent use?
For instance:
I have an old but high-end model 4870 laying around and am contemplating adding it to a system with a 6950 to boost my mining horsepower (and maybe provide a workaround for mining and viewing video without seizing up the entire system and having to hard reset), OR putting it into a different desktop with a 5450 in hopes of gaining some gfx muscle for HD/high-res video viewing on a large display/monitor/tv while solely using the 5450 and maintaining low-power for normal computing usage.
Can multiple gpus be used independently with the same function of each as if they were alone? And can the secondary graphics card go idle/off so that it isn't eating watts and producing heat sitting there while the primary alone is used? I don't want to add heat or power consumption to the system any time the computer is running, just when I am actually using the dang thing.
For instance:
